transmission delay 2 seconds before going into drive
So now the jerking is gone after trying the PCM relearn process, but it still has a delay when going from P to D...Also when it comes to stop it seems like the car will stop and then car will jerk just a bit...when going to drive it wont pick up after stop RPM will go up then car will shift, but once the car is moving the gears shift properly.I was thinking maybe the programing is off or maybe the pressure switches? has anyone had this issue?
What year vehicle is this?
Originally Posted by PAhonda
(Post 367789)
Originally Posted by jits1980
(Post 367787)
but it still has a delay when going from P to D...Also when it comes to stop it seems like the car will stop and then car will jerk just a bit...when going to drive it wont pick up after stop RPM will go up then car will shift, but once the car is moving the gears shift properly ... has anyone had this issue?
On a good vehicle, I'd probably do two or more drain and fills of AT fluid in a row (each typically replaces ~30% of total fluid) separated by >5 or 10 miles of driving. Use Honda brand fluid. Best. |
Having the fluid changed is a good idea. Use Honda fluid. Take a look in the owner's manual to see when it should be changed. Check the fluid level (as described in the owner's manual) before changing to see if you lost fluid.
You mentioned PCM relearn process, so was some work done on you car before? You may want to get the codes scanned. Most parts stores do this as a free service. Post the actual code on here, like P1234, or let us know if you get no codes. |
the car was in a minor accident and the had removed the air filter assembly and front end...The Code was P0962 Pressure Control Solenoid which was replaced with a new one and check engine light and Flashing D was gone. There are no codes on the system and car has going through all monitors and everything is reset...I have ordered both pressure switches from the dealer along with the Transmission Fluid for a Drain and Refill.
(Post 367809)
You mentioned PCM relearn process, so was some work done on you car before? You may want to get the codes scanned. Most parts stores do this as a free service. Post the actual code on here, like P1234, or let us know if you get no codes. Symptoms are when shifting from P to R or D the RPM will jump from 1000 to 1500 then shift jerking it into gear, also when coming to stop, the car will stop and then the transmission will catch up seems like and have a subtle jerk on the stop. When going from Stop to gas the RPM will jump before the car will go causing it to jerk if i step on the gas hard....Can only help? or share your experience? |
i havent done the drain and fill 3x just once so far do you think i should do it 3x? the fluid was looking clean and red when i drained.
(Post 367846)
Originally Posted by Mikebike125
(Post 367856)
I don't know if you mean you HAVE done the 3x or you HAVE NOT. Either way, you most definitely want to change the fluid doing the 3X method. I would just change it and drive it for 5 minutes and make sure you put it in reverse and run through all the gears, then move on to the second and third change. Change the fluid every 30K miles or sooner.
| All times are GMT -5. The time now is 06:26 AM. |
