Transmission or engine mounts?
My 98 Accord EX V6 3.0 sometimes takes a second or two before I can feel the gear shift, or at least that's what I believe it is. When I switch from park to drive, or drive to reverse, a second or two later it will buck or jerk a little bit and I'll hear it do so.
Do revitalizant or any other oils I see marketed in Popular Mechanics for transmission really help make it better? Can anyone attest to that? Thanks
I see one product that says it "reverses wear" and "coats vital transmission parts" and I want to know if that can noticeably effect the transmission.
Best write up I've found to date on this issue:
http://www.sonnax.com/system/pdfs/35...pdf?1320330979
Can't say this is "the fix" but someone went thru a ton of testing.
ruski9t
Aug 11, 2008 05:21 PM
