Transmission or engine mounts?
Old Oct 30, 2012 | 06:55 PM
LordAccord's Avatar
Default Transmission or engine mounts?
My 98 Accord EX V6 3.0 sometimes takes a second or two before I can feel the gear shift, or at least that's what I believe it is. When I switch from park to drive, or drive to reverse, a second or two later it will buck or jerk a little bit and I'll hear it do so.
Do revitalizant or any other oils I see marketed in Popular Mechanics for transmission really help make it better? Can anyone attest to that? Thanks
I see one product that says it "reverses wear" and "coats vital transmission parts" and I want to know if that can noticeably effect the transmission.
Old Oct 30, 2012 | 06:56 PM
LordAccord's Avatar
Old Oct 30, 2012 | 09:43 PM
The 98-02 V6 transmissions were known to have transmission failures. When was the last time you changed the transmission fluid? What brand of fluid did you use?
Old Oct 31, 2012 | 11:16 AM
LordAccord's Avatar
I bought the car in the beginning of July so I haven't changed the fluids yet.
I know it won't help me, but why were the transmissions problematic for that time frame?
Old Oct 31, 2012 | 12:21 PM
Best write up I've found to date on this issue:
http://www.sonnax.com/system/pdfs/35...pdf?1320330979
Can't say this is "the fix" but someone went thru a ton of testing.
mpanelli
Nov 9, 2014 08:39 AM
19962door
Oct 23, 2008 11:52 AM
ruski9t
Aug 11, 2008 05:21 PM
BuntinBoy9
Feb 17, 2008 02:51 PM
falkore24
Dec 3, 2007 03:56 PM
