Transmission Followups
Im new to your forums and have spent the past few hours reading through the DIY section (Lots of great info in there btw) and doing some searches of my own. My questions are centered around my transmission right now.
I have been hunting information on "hard" shifting and a kind of "lunk" downshift to 1st gear when slowing to a stop or to turn in somewhere. I just got a 96 Accord LX 4cyl from my mother. It had a bad transmission (slipping in every gear and after 10-12 miles wouldnt even come out of 2nd). So I found a tranny at the local import salvage yard for $400 + $250 installed. They used ATF-Z1 fluid and was insistant to never use anything but that if I had to add to it later in its life. It had\has 138,000 miles when this was done. I just picked it up today and the engine light came back on b4 I got home. I had AZ clear it for me and went on home. I noticed that there is definately no slipping in shifting but it is kind of a hard shifting. BTW: The engine light was on b4 I took it to have the tranny changed out.
I was just wanting to get some input from anyone with some insight and also find out if the rest of the guys whos articles I have read about similar things, have had any luck with the Lubeguard additive? I was advised to never put anything like that into a Honda tranny, but I am reading otherwise and would just like to know more about it.
I also have a somewhat low idle @500-600 rpm most of the time. I plan to change the fuel filter and try the EGR channel & ports cleaning and the ?fast idle valve? cleaning to see if it helps a little.
Any input is greatly appreciated. And the site is great![sm=smiley20.gif]
Switch to Honda ATF, get about 10 bottles of the stuff, drain the tranny (I think only 3 or 4 quarts will drain), fill it up, drive around a few miles, then repeat the process 2 more times, that's probably the cheapest, easiest and quickest way to see if you can fix the issue with a fluid change, Depending on the severity of the "clunk" and hard shift it might just cure your issues.
ORIGINAL: sir_nasty
if the D4 lite is on, you need to read the code and post it here ... also i would have them ch the adjustment on the tranny throttle cable ... And DO NOT add any additive to the tranny
As for the low idle , try cleaning the throttle body first ,also remove the adjuster screw and clean the passage as well , then readjust the idle , engine warm at about 700-750- in park or neutral
The only code that Auto Zone got was P0740 -[/b] Torque Converter Clutch circuit.
I've read that this could be afew things, some not as serious as others. This morning as I headed home from work, the shift didnt seem as harsh as it did yesterday when I picked the car up. But it does seem to take an extra second to go into gear when going from Rev to Drive4. But as I said, the shift is a little better.
Thanx Deserthonda thats yet another no to additives.
ORIGINAL: fatboy77
The only code that Auto Zone got was P0740 - Torque Converter Clutch circuit.
if all the pressures are ok, they are saying to replace the lock up control solenoid valve, ,, reset the ecu ( just remove the back-up/ radio fuse from under-hood fuse box) for about 20 seconds,
test drive the car at a steady 50 mph for about 3-5 minutes.
if code comes back on they say to replace the torque convetor and or the tranny ..
you might want to have a shop test the lock up control solenoid valve before replacing it..chk the connections, the wiring ,
Did the used tranny come with the valves ?? lock-up and shift solenoid valves ??
ORIGINAL: deserthonda
Thanks
This is for DH. Like most persons on the forum, I highly respect your opinions. I find your postings very helpful. However, I'm a bit confused about the Lubegard issue. Honda itself has recommended it's usage as a possible cure for harsh shifting. This is the only additive so recommended.You seem to disagree with this.....why? I would be very grateful if you could further explain yourstance, as I'm also suffering from harsh shifting and about to try Lubegard. Thanks
Accord_Ras
Not to thread jack or anything but I was curious where you saw the honda recommendation. I've also always been under the impression that you shouldn't use it but I've never seen any documetion one way or the other and would like to finally have an answer, do you have a link?
