Transmission Goes Out After 20 Minutes of Driving
Old May 25, 2012 | 05:45 PM
erader00's Avatar
Originally Posted by crispin
Yes - recommended is to do it 3 times.
What trans fluid are you using?
I used Valvoline Maxlife Dex/Merc because I couldn't get any Honda ATF last night. I wanted to get some new in as soon as possible. Flush out the old and then leave Honda ATF once I can get some.
Old May 25, 2012 | 06:02 PM
crispin's Avatar
Then you need to fill and drain 3 times with Honda ATF
That Dex/Merc is worse then the old fluid - IMO
Old May 25, 2012 | 07:38 PM
Honda transmissions are picky about the fluid. Hopefully changing with Honda ATF will solve the problem. Just remember that the 98-02 transmissions were prone to have failures.
Old May 26, 2012 | 01:29 AM
94ex915's Avatar
Almost A Senior Member
Is Honda ATF really that much better or is it just recomended for these cars? Think I need to do a change as well.
Old May 26, 2012 | 06:51 AM
crispin's Avatar
Read the quote above you then read it again.
I put some Mer/Dex in my car and 6 months later mine blew.
Many others have had the same experence.
These transmissions like Honda Fluid Only
Old May 26, 2012 | 08:14 AM
erader00's Avatar
Do I need to go the dealer to get Honda ATF?
Old May 26, 2012 | 08:24 AM
  #17
crispin's Avatar
Yes you do or you can order it online but I recommend you ASAP change your fluid to HONDA fluid.
Old May 26, 2012 | 08:26 AM
  #18
crispin's Avatar
I would buy 10 quarts drain your fluid, add 3 quarts drive it a for a few miles and repeat procedure 2 more times making sure to fill to the correct level on the 3rd fill which should be about 2.5 quarts.
Old May 26, 2012 | 08:44 AM
  #19
Again, there was another post today about this....not sure if this is the same.
I know that carquest carries Honda DW-1 fluid, I think for $8. I'm betting you can get it for less from the dealer since they have to buy if from a dealership and re-sell it. Or you can look online for someone selling it - ebay?
Old May 26, 2012 | 02:07 PM
  #20
94ex915's Avatar
Crazy stuff. I guess I will be picking some up when I change mine.
