transmission shifting late
Old Dec 29, 2010 | 03:32 PM
wunderbra's Avatar
Default transmission shifting late
My 97 Accord EX wagon, 165k miles; The transmission upshifts late. Even when I am not on the accelerator hard, like driving through the neighborhood, the shift from 1-2 and 2-3 are pretty late, high rpm.
I have changed the fluid in the pan three times in the last month ( W/Honda fluid), but no change.
No CEL;s. Could this be the shift solenoids? Is there an adjustment?
Old Dec 29, 2010 | 06:36 PM
There is a transmission throttle cable linkage that is adjustable (at least on 94 and likely on 97 Accord as well). The trans throttle cable linkage should be adjusted so the throttle plate and trans throttle arm begin to move together. This adjustment can have a dramatic effect on shift quality.
Suggest you download a 94-97 Accord manual via Online Manuals links in the DIY forum.
Old Dec 30, 2010 | 12:34 PM
wunderbra's Avatar
You were right. I found a little extra slack in the accelerator cable. A couple turns of the adjusting nuts at the cable bracket, and the shift points are correct now. Thanks Hondadude. Now I just have to get up the nerve to pull the instrument cluster to change the bulb in the transmission gear D light and one other.
cincyaccord
Feb 13, 2010 08:18 AM
shalak123
Nov 23, 2009 12:03 AM
willys.51
Aug 3, 2009 01:34 AM
willys.51
Jul 31, 2009 07:24 PM
Mobile05
May 19, 2005 06:03 PM
