transmission shifting problem
Old Aug 2, 2008 | 05:10 PM
Iceman
Default transmission shifting problem
I have a 1992 Honda Accord EX sedan with 185,000 miles. I have an intermitant transmission shifting problem. (auto trans.) When I turn the ignition to start the car, it turns over, but won't start. The Park indicator on the dash is hi-lighted, and also, the drive hi-lighter blinks. The transmission will not come out of park. If I bypass the brake safety switch, by inserting a key into the bypass slot on the console, and move the shift lever through the gears a couple of times, then put it in neutral, it will start. Sometimes, I have to do this a number of times before it starts. Anybody out there have any ideas as to the problem, and how to fix it? Thank you for any info.
Old Aug 2, 2008 | 06:02 PM
Default RE: transmission shifting problem
you wouldnt happen to have a audi a4 would you.............iceman
chouwalker
Sep 23, 2009 07:20 AM
93AccordCoupeLX
Mar 26, 2008 03:58 PM
crwkmd
Oct 17, 2007 04:06 PM
dan
Nov 21, 2006 04:07 AM
reddcode
Jan 15, 2005 06:11 PM
