Transmission Shifting
Old Oct 16, 2007 | 07:41 PM
crwkmd
Default Transmission Shifting
2003 Honda Accord V6 EX revs before shifting between Second and Third Gear and acts like it Slips or something. Honda Place done flush kit and replaced oil, before it was worse than it is now, it would do it in the other gears sometimes to, do you have any suggestions.
Old Oct 17, 2007 | 12:07 AM
superballz00's Avatar
Almost A Senior Member
Default RE: Transmission Shifting
Is the tranny fluid still dirty? Was that the first time you had your tranny oil replaced? If so how many miles does the car have?
Old Oct 17, 2007 | 01:31 PM
crwkmd
Car has 116000 miles, oil had never been changed, don't know how many times Honda flushed but I assume on time, don't know
Old Oct 17, 2007 | 01:51 PM
smaglik's Avatar
how long have you owned the car? should be changed every 15k miles.
i think you're out of extended warranty on it...if it was ever covered.
You shouldnt flush the trannys on these cars. Just drain, replace, drive, x3.
Old Oct 17, 2007 | 02:06 PM
falkore24's Avatar
are you sure that this is happening on the 2-3 shift and not 3-4? On 3-4, this is normal (lock-up solenoid disengaging).
Old Oct 17, 2007 | 04:03 PM
crwkmd
I bought the car brand new and I am pretty sure that it is between second and third gear it has gradually got worse, changed the oil and it is better, but still the same problem.
Old Oct 17, 2007 | 04:06 PM
falkore24's Avatar
Do a few Honda ATF changes ad look for the tranny cooler DIY.
chouwalker
Sep 23, 2009 07:20 AM
Iceman
Aug 2, 2008 06:02 PM
93AccordCoupeLX
Mar 26, 2008 03:58 PM
dan
Nov 21, 2006 04:07 AM
reddcode
Jan 15, 2005 06:11 PM
