transmission won't shift to overdrive
95 Accod AT
I was driving down the road when the car sputtered and lost drive as if it was in nuetral. It shifts good to 3rd but when it shifts to OD it acts like it is in nuetral.
It also has a hum to it mainly when I let off the fuel.
Engine code reads 12 but I assume that has nothing to do with transmission?
What do I need to do? Thank you!
Anyway, now the fluid level is fine. What would be next? Solenoids?
I have never changed the fluid however recently I did have a transmission leak and added 2 quarts I am not sure if that cause the issue or not as I noticed the leak while it was parked but I cannot verify when it started.
thunder_x
Jul 4, 2006 01:31 PM
