2007 Accord Transmission Flush
Old May 24, 2019 | 05:10 PM
Longdraw's Avatar
Default 2007 Accord Transmission Flush
Gents,
i have learned today that my 2007 Accord had a transmission flush. I just bought the car and saw
the notice on Carfax. The trans flush happened 4,000 miles ago. I called Honda and I can to a trans flush and fill. Honda doesn’t do flashing but they suggested doing a drain and fill and do it about every 5000 or so miles. Opinions would be valued here. The transmission has Valvoline full life synthetic.
Old May 24, 2019 | 05:49 PM
I think 20,000 miles is a better interval. But since it has Valvoline fluid, you might want to do 3 drain & fill cycles to get that out.
I wouldn't trust Carfax to use the proper terminology. Even some dealers say "flush" when they actually mean drain/fill.
I would only use Honda ATF.
Old May 24, 2019 | 07:57 PM
shipo's Avatar
Agreed, get that Valvoline stuff out of there, it is NOT approved for use in any Honda transmission. As @JimBlake wrote, perform a "3x3" transmission drain/fill operation (three consecutive drains and refill with three quarts of DW-1).
Old May 25, 2019 | 03:52 PM
Longdraw's Avatar
I did call the shop that did the flushing. They actually told me they did flush the transmission. I talked with Honda and they did the drain/fill with the right fluid. They told me not to worry and should wait 20,000 miles for the next service. But I do agree with y’all about the “3x3”. So should I drive a few thousand miles then do another drain/fill? I am a little paranoid here. Had a bad experience with my 2005 Accord because i flushed the transmission with different fluid. I learned my lesson and now do my homework.
Old May 25, 2019 | 06:31 PM
Is it a CVT? I don't think Honda had that type of transmission in 2007?
Are you able to change your own oil? Drain/fill the transmission is about as easy as that.
The 3x3 seems more important when the fluid is all muddy & full of crud. But I'd probably worry just like you about having the wrong fluid. In between the drain/fill cycles, you only need to mix the fluid up good. Some people drive around the block, others wait a couple days or a week just for their own convenience.
Old May 26, 2019 | 08:52 AM
Longdraw's Avatar
I was thinking the same thing about just doing the drain/fill myself. I need to know the exact type of transmission fluid as well just to be sure. Would happen to know what type of Honda transmission fluid?
Old May 26, 2019 | 08:55 AM
shipo's Avatar
Honda DW-1; accept no substitutes.
Old May 26, 2019 | 09:27 AM
Longdraw's Avatar
Was just looking at the DW-1. Thanks guys. Y’all are a big help and blessing.
Old May 26, 2019 | 12:56 PM
The Toecutter's Avatar
Yup, look in my signature.
Old May 27, 2019 | 07:10 AM
Longdraw's Avatar
Just bought a case of the DW-1. I will be doing the drain/fill once or twice in the next month or few weeks. Thanks for all the input!
islandpassion
May 13, 2012 12:26 AM
Max Utility
Apr 16, 2012 04:47 PM
staunch1
Dec 1, 2008 08:39 AM
dtcaccord
Jun 4, 2008 09:54 PM
hondaR
Sep 22, 2007 11:34 PM
