Tune-Up Time
I have a 1992 Accord LX with 50,000 miles on it.
It's time for a tune up, so what spark plug wires should I use? Also how about the distributor cap & rotor? And I was told by a Honda tech that I should replace the transmission fluid. Is it OK to have it done at places like Jiffy Lube or Xpress Lube? Lastly, the window washers only squirt about 2--3 inches--- could the squirters be clogged or is the pump going out? Thanks. Hope everyone has a nice weekend. :) |
I would get NGK plugs.
Cap and rotor - can be a debate, I use aftermarket others will go OEM. Changing the trans fluid is pretty simple - if you can change the oil you can do the trans fluid. For the washers - I'd start with trying to clean them. I use a "bread tie", strip off the plastic off the wire. Then gently insert the wire into the holes. |
Where the heck did you find a 92 with only 50k on it????
