Tune-Up Time
Old Jul 12, 2013 | 08:28 PM
drumdoctor's Avatar
Default Tune-Up Time
I have a 1992 Accord LX with 50,000 miles on it.
It's time for a tune up, so what spark plug wires should I use?
Also how about the distributor cap & rotor?
And I was told by a Honda tech that I should replace the transmission fluid.
Is it OK to have it done at places like Jiffy Lube or Xpress Lube?
Lastly, the window washers only squirt about 2--3 inches---
could the squirters be clogged or is the pump going out?
Thanks.
Hope everyone has a nice weekend.
Old Jul 14, 2013 | 06:18 AM
I would get NGK plugs.
Cap and rotor - can be a debate, I use aftermarket others will go OEM.
Changing the trans fluid is pretty simple - if you can change the oil you can do the trans fluid.
For the washers - I'd start with trying to clean them. I use a "bread tie", strip off the plastic off the wire. Then gently insert the wire into the holes.
Old Jul 14, 2013 | 06:48 AM
kayweb's Avatar
Where the heck did you find a 92 with only 50k on it????
Jeff247
Jan 4, 2016 07:32 PM
800block
Apr 5, 2010 02:00 AM
9JordonFlex9
Aug 14, 2006 04:26 AM
ondaslab
Jul 14, 2006 01:11 PM
EternalBuddha
Apr 16, 2006 09:34 AM
