Turbo
Old Jan 18, 2008 | 08:15 PM
94CFaccord's Avatar
Default RE: Turbo
i gotcha ...well the motor is fairly new with prolly about 65,000 miles on it got intake full exhaust header...new ecu no a/c.....idk i was thinking it would be at least above 200 horses on the motor....its a T3/T4 turbo with a 63 trim
Old Jan 18, 2008 | 08:25 PM
BlkCurrantKord's Avatar
Default RE: Turbo
You'll be over 200 with some good tuning.
www.spoolinperformance.com - has a nice log and tubular manifold(s).
Old Jan 18, 2008 | 08:28 PM
94CFaccord's Avatar
Default RE: Turbo
ok well you know any place were i could get a F22B1 turbo manifold cuz the one i got is for a H22...doesnt work....and from what ive read its best to have someone fabricate a downpipe to fit
Old Jan 18, 2008 | 08:46 PM
00accorddriva's Avatar
Default RE: Turbo
the downpipe would be simple to make. ive made a few, just find somebody handy with a welder and find a piece of plate for the flange and their you go. i havnt looked myself but i would imagine ebay has something.
All else fails GOOGLE it!! hehe always works. good luck with it and gkeep us posted
Old Jan 18, 2008 | 09:28 PM
94CFaccord's Avatar
Default RE: Turbo
another thing is what all things do you need for a turbo setup....like of course i know you know a turbo intercooler wastegate bov piping oil line gaskets boost control..what else like maybe injectors fuel management system fuel pump or what is necessary for safe setup
Old Jan 18, 2008 | 09:37 PM
Default RE: Turbo
not sure how your injectors are rated. you need to check into it more. if you need injectors well then you need a fuel pump. do some research a pump is about 99 bucks for a walbro.
you will need a custom mapped ecu so look into that also.
lots of things you have to do. to me it is just easier to get a car already turboed.
Old Jan 18, 2008 | 10:10 PM
  #17
94CFaccord's Avatar
Default RE: Turbo
well i have a chip on the car right now that erased the governor and rev limiter....and changed the air/fuel ratio....but like what kind of mapped ecu...is there a special ecu thats good for a turbo setup and i once heard you shouldnt change the stock ecu out if your going to turbo your car...im not sure on the injectors either but yea it would be a good thing to change and get a new fuel pump as well
Old Jan 19, 2008 | 07:42 AM
  #18
Default RE: Turbo
All the regular stuff you mentioned...plus..
DSM Blue top 450cc Injectors
P28 chipped ECU with Crome, Neptune, ECTune...(look them up on Honda-Tech)
FYI - a turbo manifold listed for the F23 will fit your F22B1 aka spoolin performance
Old Jan 19, 2008 | 02:07 PM
  #19
94CFaccord's Avatar
Default RE: Turbo
well i got an ecu thats really good actually but idk if it has all the stuff you said or whatver and so i need the injectors and F23 manifold will fit huh ok i will check it out thanks
Old Jan 19, 2008 | 02:11 PM
  #20
94CFaccord's Avatar
Default RE: Turbo
well i found some on ebay but i need the manifold to come down alittle bit ....ummm you think a manifold from a eclipse would fit ....the DSM g2 manifold...would that fit as long as they have even port 0-0-0-0 it should fit..i heard you just have to make the ports alittle bigger i think
