Turbo
Old Jan 19, 2008 | 02:17 PM
  #21
sir_nasty's Avatar
Default RE: Turbo
Someone else can verify this but for 8psi I don't think you need to upgrade those injectors..... I'm pretty sure the stock ones will handle it.... as for parts check this place out
www.f22parts.com
Old Jan 19, 2008 | 05:08 PM
  #22
nafango2's Avatar
Default RE: Turbo
thats what ive always heard. Anything >8psi would most likely need injectors. However wait for someone thats done this to clarify.
you should also install a A/F radio gauge to examine whether you need new injectors/pump or not. If it starts to run lean at high rpms/speeds, you most likely need new injectors/fuel pump. (assuming its tuned correctly)
Dont hesistate if its running lean though! you can pretty easily melt a piston on a lean-running engine.
Old Jan 19, 2008 | 05:11 PM
  #23
sir_nasty's Avatar
Default RE: Turbo
Here's one of the mac daddy threads of turbo information from a long time ago.... it's got LOADS of info about turbo's, injectors, tuning etc
https://www.hondaaccordforum.com/m_9882/tm.htm
Old Jan 20, 2008 | 01:21 AM
  #24
BlkCurrantKord's Avatar
Default RE: Turbo
The one thing you shouldn't ever skimp on is fuel delivery. A higher flowing fuel pump and larger injectors are a nice safety cushion. Whether you need it or not, at some point you're going to want to up the boost at some point. DSM manifold will not fit.What ECU do you have now?
Also, gettinga wideband to find out if you're running too lean just so you can verify needing a pump/injectors is just stupid and *** backwards.
Don't buy from F22parts, they have the worst customer service and don't even test their own products.
Old Jan 20, 2008 | 12:45 PM
  #25
94CFaccord's Avatar
Default RE: Turbo
idk what ecu it is .....its the stock ecu with a skunk2 chip in it..so i dont know what model the ecu is in my car....and yeah i prolly would buy the injectors and a fuel pump no problems there....but i dont get the lean part....whats it mean running lean...like to rich or what....is there a manifold that does fit the F22 besides the F23 cuz i cant find what i need. the manifold i find will not support enough space for the turbo with the fans right there....
Old Jan 20, 2008 | 12:48 PM
  #26
94CFaccord's Avatar
Default RE: Turbo
here how bout this manifold you think it would fit
http://cgi.ebay.com/ebaymotors/Prelu...em370014223381
Old Jan 20, 2008 | 01:46 PM
  #27
94CFaccord's Avatar
Default RE: Turbo
alright well scratch that idea...i need someone that has a turbo on there F22B1 to tell me where they got there manifold from so i can get one....
Old Jan 20, 2008 | 04:25 PM
  #28
Default RE: Turbo
ORIGINAL: 94CFaccord
Stock ECU with skunk2 chip? Skunk2 doesn't make chips for ecu's. Sounds like an ebay product. Either way that ecu won't do you any good if you go turbo.
Running lean is too much air and not enough fuel. Things get very hot when this happens, its how you melt pistons. Running rich is just the opposite, too much fuel and not enough air.
I already linked you to this but I guess you didn't find it - http://www.spoolinperformance.com/lo...fold-p-58.html
Another one - http://www.importparts.com/shop/prod...oducts_id=2208
Old Jan 20, 2008 | 06:08 PM
  #29
94CFaccord's Avatar
Default RE: Turbo
cant you just use a stock ecu...it may not give you all the horse power or whatever but it shouldnt affect how a turbo runs
Old Jan 20, 2008 | 06:13 PM
  #30
00accorddriva's Avatar
Default RE: Turbo
if the accord is the same as a civic ecu i turboed my brothers 1.6 and a guy close buy programs the small chips for 20 bucks according to what mods u got and so on. it is quick and easy to change. you can go and get a full ecu also.
