update and new contention/91ex/5spd
so far the won't run hot seems to have been cured with the fuel filter
maybe i will change it in a more timely fashion from now on 271k on original filter may have been a stretch:rolleyes: new issue is the power steering acting up it seemed to act a little irratic, checked fluid, topped with honda fluid turned wheel lock to lock and foamed out very brown and a little burnt smelling now its back at the lower level and i noticed a vibration in the hose from the pump to the rack which i hadn't recognized earlier pump itself is not noisy butthe steering is not like it should be maybe delayed would describe it best no obvious leaks possibly new fluid is the best starting point the hose vibration is a concern, fluid path is restricted or something causing irratic/delayed feel @ steering wheel:confused: thankx for having a look |
In the bottom of the res there is a filter/screen that might need to be cleaned....I think the only way to replace it is with a new res.
Inspect all of the hoses for signs of leaks....not only leaking fluid out (usually pressure side) but also where it might be sucking air in. |
