Upper Distributor Bearing
Old Jun 10, 2006 | 11:30 PM
drcoopster
Default Upper Distributor Bearing
I understand that a lot of early 90s Accords have problems with the distributor bearing going. What has y'all's experience been with this? Does anybody have a failed distributor that you would be willing to send me--I am looking to see if I can find a local source for the bearing itself.
Thanks,
-Ian
Old Jun 11, 2006 | 12:48 AM
lightshow's Avatar
Default RE: Upper Distributor Bearing
how many miles do you have. i have 258 on my 91 and no bearing problems
Old Jun 11, 2006 | 12:51 AM
drcoopster
It seems that they tend to fail rather early. My friend has a '92 Accord with something like 110K miles and his bearing just went. In researching the problem, I came across this article (http://www.findarticles.com/p/articl...04/ai_n8801285) and was just wondering if anyone else had the same failures.
-Ian
Old Jun 11, 2006 | 05:15 AM
deserthonda's Avatar
Honda had a service news on this, we used to stuff grease in the upper bearing..
get any sturdy hose, make sure it fits snuggly on the upper distr shaft, put some grease on the top bearing and with the hose push down on the grease,, what this does is,, it forces the grease into the bearing prolonging its life and avoiding noise and wear..
i did a couple dozen in the mid 90s , it worked well , it also quieted down some distributor noise coming from dry upper bearing .
Old Jun 11, 2006 | 01:38 PM
Chiovnidca's Avatar
ORIGINAL: deserthonda
That was just a bandaid, they'ld be back a year later. They updated the bulletin shortly after to relace the distributor.
Old Jun 11, 2006 | 02:13 PM
YeuEmMaiMai's Avatar
can the bearing be replaced on the distributor?
Old Jun 11, 2006 | 03:58 PM
drcoopster
ORIGINAL: YeuEmMaiMai
That's what I'm trying to figure out. It's like pulling teeth on here. I just need to know the size of the bearing; I'm not going to pull the distributor unless I have a replacement bearing to put back in because it's my friend's only transportation.
Old Jun 11, 2006 | 10:08 PM
is it noisy??? or is it worn and the distr shaft wobbles??? chk angine lite on ?? runnubility issues ??
if just noisy , try to stuff some grease in there , if not damaged yet you will be surprised how much longer it will last ..
Old Jun 11, 2006 | 11:29 PM
Chiovnidca's Avatar
Yea, it sure can. I've seen kits sold on ebay to do it. The parts are not available from the dealer.
Old Jun 12, 2006 | 12:28 AM
ORIGINAL: Chiovnidca
Yo Chio...... do you know if it comes with the lower inner shaft seal ?? or do you have any ideas where i can get my hands on a few of those ..??
i got a couple of customers with oil leaking inside the cap .. i would hate for them to spend all that money and replace the distr sub-assembly , when all it needs is a 2 dollar seal.
