urgent electrical help please
Old Aug 13, 2008 | 01:03 PM
clutch811's Avatar
Default urgent electrical help please
ive recently decided to finally add a cd player to my car as i bought it without one. i did the wiring harness and set it up correctly but it doesnt play through my speakers. it kicks on and works but no sound. there are front pioneer speakers and just a working stock in the back. is there something loose somewhere that may be causing this. my front courtesy lights also dont work and im wondering if there is a relation somewhere. my rear ones work. i checked all my fuses but im still not sure. any ideas???
Old Aug 14, 2008 | 12:53 AM
clutch811's Avatar
Default RE: urgent electrical help please
no fix yet bump
Old Aug 14, 2008 | 01:59 PM
Did you install a new radio unit, or just a CD player to attach to the original honda unit?
Old Aug 14, 2008 | 02:06 PM
falkore24's Avatar
Re-do all connections with solder and shrink-wrap. If that is too much work, use plastic shielded butt splice connectors for a solid connection.
Twist and tape connections are not reliable.
Old Aug 14, 2008 | 04:25 PM
clutch811's Avatar
thanks for the replies but i got it fixed. the head unit was bad. it came on but i guess something else was blown. got a nice kenwood and it works great. still need help though. the front right and left courtesy lights still dont work any ideas there?
Old Aug 14, 2008 | 04:46 PM
falkore24's Avatar
glad you got it fixed. Courtesy lights sound like a fuse since the problem is with both.
Old Aug 14, 2008 | 09:13 PM
clutch811's Avatar
thanks i was pretty happy bout it. i checked my fuses and im sure all are fine. do you know off hand which fuse would go to just these two front lights. maybe i just cant tell.
Old Aug 15, 2008 | 01:18 AM
Which lights are the courtesy lights?
Old Aug 15, 2008 | 08:20 AM
quickkris2006
the lights that come on when u open the door
Old Aug 15, 2008 | 10:41 AM
Fuse #37 (7.5 amp) in the engine bay fuse box protects that circuit.
Pull the bulb (check that it isn't burnt out) in the door and check that the wht/blu wire should be hot at all times. The grn/red wire should be grounded when the door switch is open, and that wire should be open to ground when you push that door switch closed.
Figure which side of the circuit is faulty, then work back from there.
99accordf23a5
May 6, 2014 12:51 AM
hallacam
Jan 30, 2010 08:42 PM
kysit
Nov 25, 2007 05:44 PM
aqbui
Jun 13, 2007 09:24 AM
accord93
Apr 27, 2007 01:04 PM
