Urgent: Stuck Window Help
Old Oct 26, 2014 | 03:55 PM
cukaracha's Avatar
Default Urgent: Stuck Window Help
Hello,
My rear driver side windows is stuck and I'm trying to get it back up. Here's the situation:
Window rolls down fine, but when I try to roll it up, the motor doesn't turn on at all (no clicking or any sound whatsoever). I tried using the switches from the other doors (which I know work fine), but the same condition prevails. Interestingly, if I disconnect the switch from, say the front passenger side, I can't control that window from the driver side either. The same applies to all doors.
Any idea how I might fix this quickly?
Thanks!!
Old Oct 26, 2014 | 05:37 PM
cukaracha's Avatar
Okay so I took apart the motor assembly and hand-cranked it. Got the window back up and it isn't going anywhere for now.
Thanks again.
Old Oct 26, 2014 | 06:18 PM
This would be explained by a switch fault in the LR switch assy at the master switch panel (driver's door). Suggest removing/cleaning the master switch panel LR switch assy.
cukaracha
Apr 16, 2015 06:55 AM
Akkord 03
Jul 24, 2009 09:57 AM
kysit
Nov 25, 2007 05:44 PM
aqbui
Jun 13, 2007 09:24 AM
accord93
Apr 27, 2007 01:04 PM
