VSA/brake/Abs light on 2008 EX V6 3.5
Old Nov 8, 2019 | 08:48 AM
Rchavesaguiar's Avatar
Unhappy VSA/brake/Abs light on 2008 EX V6 3.5
HEllo guys,
So, my honda accord 2008 3.5 v6 sometimes lights going up (VSA/ABS/BRAKE) ,but if i turning off the engine and start,de lights turning down.
I passed the PDL scanner ,show me this codes :
Fail solenoid 121-21 and 121-01
Anyone Have ideia for de fix it ?
att,
Honda accord 2008 V6 3.5 with 80.000 miles
Old Nov 8, 2019 | 11:22 AM
rockhoundrob's Avatar
Likely you have a bad ABS control module.
Old Nov 9, 2019 | 10:08 AM
So, this piece “ modulator abs “ is not same the crv 2009/10 ??
Old Nov 9, 2019 | 12:57 PM
Your codes are for a solenoid valve issue that is part of the vsa module. Looks like Honda sells the entire module and is very expensive. You could always get a used part for less money.
Depending on your skill level, you may be able to replace the solenoid valve on the module, or see if the issue is something simple.
Old Nov 9, 2019 | 01:15 PM
PAhonda , this solenoid is not the same Honda accord 2.0 ?
Old Nov 9, 2019 | 03:10 PM
What solenoid are you asking about from the Honda 2.0?
Old Nov 11, 2019 | 09:38 AM
Try this... https://www.myairbags.com/product-ca...n/abs-modules/
I sent my ABS ( General Motors Car) here. Got it back in 1 week. I don't see 2008 Honda Accord, but you can call them and see if they will repair it.
Note, on my GM car, I could remove the module only (not the whole ABS unit) and sent it in. They sent back the same unit to me and I put it back on. Been good for 2 years now.
My choice was something like
1) -$500 for the Module part from the dealer,
2) -$1200 for the dealer to get the ABS and put it in
3) - I take the module off and send it to MyAirbags.com for something like $150 (shipping included).
Took me about 1 hour to take it off and 1 hour to install.
Old Dec 13, 2019 | 01:18 PM
Default Solved.
Hy guys,i solved this problem in Brazil.
Let me speak in portuguese.
O problema ocorre em todos os accords (parece ser um problema crônico),um capacitor que envia os pulsos para controlar e acionar os airbags abre com o tempo,após a troca,o mesmo voltou a operar sem erros no scanner.
Eu gastei 600 reais,em torno de 150 dollares.
Old Dec 20, 2019 | 02:17 AM
Sarah1279's Avatar
Default English... I beg of u cuz I don’t know portages
I don’t know how to read Portuguese
Old Dec 20, 2019 | 09:18 AM
according to google-translate...
The problem occurs in all accords (it seems to be a chronic problem), a capacitor that sends the pulses to control and trigger the airbags opens over time, after replacement, it went back to operating without errors in the scanner.
I spent 600 reais, around 150 dollars.
