VSS leak?
Is it possible for a VSS to leak steering fluid into the tranny? Just curious.
RE: VSS leak?
Where would the steering fluid come from? The VSS is simply a magnetic sensor that sticks into the tranny. Even it it's broken, you would stillneed some way for steering fluid to get poured onto the VSS???
RE: VSS leak?
My VSS is also the controller for the speed sensitive steering, so there are PS lines going to it.
RE: VSS leak?
Wow, I feel dumb; I just looked that up & you're right.
PS fluid is in there, so I guess it's possible. That VSS looks like a little pump of sorts. There has to be a shaft seal, so that would be the place. Do you see evidence of it leaking? |
| All times are GMT -5. The time now is 03:41 AM. |
