Vtec on 96 accord not working
Old Feb 11, 2010 | 10:43 PM
  #21
efster420's Avatar
So do you think im getting a full report using obd1
So this is the most likely cause why my CEL is on right
Old Feb 11, 2010 | 10:50 PM
  #22
I think that you have the problem narrowed down to the two O2 sensors.
OBD2 wouldn't detect other problems, it is just more specific for certain codes.
I just looked up the OBD1/2 codes. If you could find your OBD2 connection, the codes that you would get are P0135 and P0141.
Old Feb 11, 2010 | 10:53 PM
  #23
efster420's Avatar
Were is the first sensor located at i know its in the front
N u mentioned the second one being by the catalytic converter or
somewere around their, ill chek it when i wake up tomorrow morning
i need to pass that smog check
thnx for all your help
Old Feb 13, 2010 | 11:58 AM
  #24
efster420's Avatar
I found my obd2 connector
snaky little cable was hidden all the in the bottom of my center console been having this car for 2 weeks now and i just found it
Old Feb 14, 2010 | 01:01 PM
  #25
efster420's Avatar
So i stilll havent fixed this issue i found one of the sensors the one thats before the cat rite wen the two pipes joint toghter
I did a voltmeter check and it read 141 ohms meaning its broken and has to be replaced
But im still having issues finding second sensor
Old Feb 14, 2010 | 01:02 PM
  #26
efster420's Avatar
Ne one
Old Feb 14, 2010 | 02:13 PM
  #27
Its either bolted directly into the catalytic converter, or just past it.
skyfire322
Dec 27, 2013 10:39 AM
kshellz
Oct 24, 2012 10:51 AM
pamczc74
Dec 14, 2010 10:52 PM
arunsam3000
Mar 6, 2007 01:40 PM
