Vtec head problems
Old Nov 25, 2006 | 06:32 PM
94coupeaccord's Avatar
Default Vtec head problems
I just installed a vtec head in my car but I still have the non vtec wiring, distributor and ecu. Before I installed the vtec head my rev limit was around 8500 rpm's but after I installed the vtec head the rev limit is now 4500 rpm's in any gear does anyone know what could it be?
Old Nov 25, 2006 | 08:00 PM
sir_nasty's Avatar
Default RE: Vtec head problems
did you reset the ecu after the swap? Is everything connected? Proper timing? Any other funny things that it does or just the rev limiter issue?
Old Nov 25, 2006 | 08:17 PM
Yes everything is correct and the only problem that I have is the rev limit. Just in case I'll check the timing with the mechanic on monday.
Old Nov 25, 2006 | 08:22 PM
sir_nasty's Avatar
I assume that you did reset the ECU then? I believe it's just the #15 fuse that you have to pull for like 30 seconds or remove the negative battery cable for a few minutes and then try it
Old Nov 25, 2006 | 08:29 PM
yes I already reset the ecu.
Old Nov 25, 2006 | 08:31 PM
poser_pilot6
The VTEC wont work anyway, will it? Since its a non-VTEC ECU and wiring, I would assume that the VTEC wouldnt kick in. I know this doesnt explain the low rev limit, Im just putting it out there lol.
Old Nov 25, 2006 | 08:48 PM
Yes I know that the vtec wont work I already bought the ecu I only need the wiring. Does anyone have a vtec wiring for a 94 or 95 accord?
Old Nov 25, 2006 | 08:53 PM
poser_pilot6
I would try eBay or a junkyard, were I you.
Old Nov 25, 2006 | 08:54 PM
sir_nasty's Avatar
Here's a skunk2 wiring harness (I'm sure you could find this elsewhere as well if you search), it sounds like it is a wiring issue for sure since 4500 is the vtec engagment point and if you don't have it wired up/grounded very well then it's not going to work
https://www.elitepro1.com/vcart/item...?itemblock=112
Old Nov 26, 2006 | 10:29 AM
YeuEmMaiMai's Avatar
first off you need to get the right ECU and then run the wire for vtec. Since you are rev limited to 4500, you need to pull the code (there should be one stored)
