Warranty Void?
i went to a goodyear dealer today to get my oil changed and tires rotated. the guy at the counter said he used to work at a honda dealership n if i didnt get a 15k mile tune up, honda would void my warranty. is this true, or was he just trying to get $300 out of a teenage kid?
RE: Warranty Void?
he was being a bit over dramatic .. ok ... A LOT
and 300 dollars for the 15 k is way way too much all you do is , air filter, cabin filter , oil and filter, tire rotate ........and chk car over ,lube the door hinges so if they wanted to charge anything close to 300 ,, yeah you are right he was trying to get $ 300 out of anyone he could .. BIG RIP OFF |
RE: Warranty Void?
ok thats what i thought. i just got the tires rotated and my oil changed for the 3rd time. so you're saying honda wont void my warranty for sure if i dont get the 15k mile tune up?
RE: Warranty Void?
the only time I take car to dealer is when the "Big" service is due.
I don't trust anyone else with my car........... |
RE: Warranty Void?
Tell us what year/model, so we know which mileage is the BIG ones. But 15k miles is almost never a major service.
If you've only got 15k miles, the car must be pretty new. My 2003 Accord doesn't have a really major service until about 100k miles. |
RE: Warranty Void?
you almost did the whole 15k ,, all you need to do is replace the air filter and i would definately replace the cabin filter, thiose filter get nasty ,,
replacing cabin filter on your car is easy ,, I am assuming you got at least a 2003 or newer,,,, |
RE: Warranty Void?
its a 2006 accord/ lx special edition 4 cylinder. where can i find the air filter and a cabin filter to replace, cause i'd probably just do that myself
RE: Warranty Void?
remove glovebox and support bar and the filters are in the housing
RE: Warranty Void?
ORIGINAL: deserthonda you almost did the whole 15k ,, all you need to do is replace the air filter and i would definately replace the cabin filter, thiose filter get nasty ,, |
RE: Warranty Void?
ORIGINAL: Chiovnidca ORIGINAL: deserthonda you almost did the whole 15k ,, all you need to do is replace the air filter and i would definately replace the cabin filter, thiose filter get nasty ,, and to replace cabin filter 2003 and newer you DO NOT have to remove the glove box, just uclip it from the sides and drop it down, it takes 10 seconds,, then just remove the filter holder,, unclip it s well and install new filter,, make sure to reinstall it with the arrows pointing down ( air flow ) |
