Water Pump Install
Old Jul 10, 2012 | 09:07 PM
ArcticHonda's Avatar
Default Water Pump Install
Just curious if one is supposed to install the water pump with honda bond or a film of silicone, or install it dry with nothing but the new seal??
Old Jul 10, 2012 | 09:11 PM
I used a small amount of silicone lube on the oring. No RTV sealant is necessary.
Old Jul 11, 2012 | 07:36 PM
I use just enough on the water pump to "hold" the o-ring as you install it. You want to hold the o-ring in place as you mount the pump to the block....that is all you need.
Old Jul 11, 2012 | 09:24 PM
Just enough of what? Honda bond or grease??
Old Jul 11, 2012 | 09:48 PM
Poorman meant a little bit of honda bond on the water pump, then lay in the gasket. Like a dab in the middle of each side. Do not put Hondabond (or RTV) between the gasket and the engine block, because the next person to replace the water pump will not have a good day.
If your gasket stays in the groove without any sealant and won't fall out, then don't use anything.
Old Jul 11, 2012 | 09:50 PM
Watch this video. This is for a transmission pan, but you will get the point.
There is a gasket adhesive spray made by 3M (I think) that will prevent the gasket from falling out.
Old Jul 12, 2012 | 06:21 PM
Most water pumps have retainer tabs around the groove.
joe592
Aug 10, 2006 01:51 AM
jrcastro
Jun 20, 2006 08:28 PM
joe592
May 25, 2006 03:35 AM
F23AccordLX
Mar 27, 2006 11:50 PM
emaxxman
Feb 21, 2006 09:15 PM
