water temp
Old Mar 24, 2012 | 12:55 AM
tiledaddy's Avatar
Default water temp
my 96 accord started to heat up to half when ac was on at idle ac fan comes on but i dont think regular comes on but my temp with out ac on never goes up past a third with no fan could that be right
This is in the wrong forum member..
Old Mar 24, 2012 | 01:01 AM
Exclamation
I moved it to here...
Old Mar 24, 2012 | 07:29 AM
When the ac is on (assuming it is working) BOTH fans should come on.
Open the hood and turn on the ac, both should come on. If not, then some testing is going to be needed. If you are up to it and have a few tools, we can help with the testing. We will need a bit more information (4 or 6 cyl-which fan is not working-ect).
Old Mar 25, 2012 | 12:13 AM
tiledaddy's Avatar
Default water temp
well im might be worried over nothing
its the drivers side fan that is working and now i belive thats the main fan so it would make since that the temp would go up with ac on and no ac fan working. they both dont come on with ac running only drivers side the ac isnt super cold but with fan not working that makes since .temp with out ac does not go over a third
a new question with cap off how long would it before you would see movement in radiator i can get it up to temp (i can put a finger in it hot but not scallding) bottom hose still cold.
now once again my temp does not go over a third on the gage i just get a little paranoid with water pumps, timing belts and their adverse affects on a motor with 194000 miles
Old Mar 25, 2012 | 02:13 AM
Both fans will turn on when the a/c is turned on and the engine is running.
You need to figure out why the passenger fan is not turning on.
You want both fans to work, because the driver's side fan could stop working and cause the car to overheat. This would not be good for the engine.
The test is pretty simple. Do you have a volt meter?
The temperature of the coolant hoses sounds like the radiator is is properly removing heat from the coolant.
It is hard to see movement of the coolant through the radiator.
Bruce Andrew
Jul 7, 2010 01:02 AM
jayrod
Apr 29, 2010 04:34 PM
ezekielguy86
Sep 23, 2009 07:45 PM
raf105
Sep 28, 2007 02:55 PM
fperezal
Sep 29, 2005 09:29 PM
