Cel 6 - water temp sensor
Old Apr 29, 2010 | 03:30 PM
jayrod's Avatar
Default Cel 6 - water temp sensor
I have a 1992 accord with 218k
After driving for a few minutes the check engine comes on and the d4 light starts to blink. I pulled the codes - Code 6 water temp senor and for the d4 code 10 coolant temp senor. So, I replaced the senor, the two wire one located under the distributor. I pulled the codes and didn't get any. Went for a test drive, after a few minute the same thing happens - check engine on, d4 blinking, which sends the car into limp mode. Pulled the codes again six quick flashes - water temp senor. So, my question is what are my next steps to correct the probem. What else would cause a cel 6 to be read. Any advice on troubleshooting or input would be greatly appreciated! Thanks!
Old Apr 29, 2010 | 04:34 PM
Anything in the wiring from that sensor back to the ECU. Loose/dirty/corroded plugs in the wiring harness? Wire rubbed through the insulation to exposed the wire?
pondrun
Nov 8, 2021 09:40 AM
jhbigred
Dec 11, 2011 11:47 PM
ezekielguy86
Sep 23, 2009 07:45 PM
raf105
Sep 28, 2007 02:55 PM
fperezal
Sep 29, 2005 09:29 PM
