weatherstrip above chrome belt molding?
Hi, I have a 2010 Accord Sedan V6 EX-L and the little thin black strip that is just above the chrome trim at the base of the window has came off on one side and is peeling off on the other side. It's a little thin rubberlike piece and it looks like there are 4 pieces, one for each window. 1 is completely missing and one is lifting up and flaps around when I lower the window. Does anyone know what this is? I can take a picture or two if needed. I want to know what it is called and how hard it is to put on and whether I should pay someone to apply it for me. Thank you.
You can always try.
For replacement, if you open the door, you'll see the two screws on each end of the door frame. After those screws are removed, you would slide the molding (with the attached clips) off the door frame.
It probably helps to some degree to keep the environment out (dirt, water, etc.).
It's a dealer part. Internet dealers like Bernardi Honda, Honda Parts Now, Majestic Honda, etc. are competitive and sell below list price; but, the shipping costs can add to make it more than list.
Local dealership many times mark-up over list. So, you have to shop around and compare pricing.
