weird problem with my 99 EX
Old Apr 18, 2012 | 08:35 PM
1999EX's Avatar
Default weird problem with my 99 EX
So here's what it's doing. Occasionally after it's been running (and it's at full running temp) and you go to start it it won't start. It just turns over as if it's not getting fuel or spark. If you wait anywhere from 5-10 mins. and you try again it'll fire right up. It's never done it in the mornings after sitting overnight, just after it's at full running temp, like if you run into the grocery store for 10-15 mins then come back out. Any ideas? It otherwise runs great.
Old Apr 18, 2012 | 08:39 PM
I would stop by a parts store and have them check for codes. Post any codes on here.
You have to determine if you are missing spark or fuel when the car won't start. Do you have a timing light?
Old Apr 19, 2012 | 05:58 PM
Can I guess this is a v6?
Old Apr 20, 2012 | 08:15 PM
ghostpilot's Avatar
I have a 1999 EX and mines did this too. It would happen randomly but always after being used. It ended up being the main relay. I hope this info helps.
Old Apr 20, 2012 | 11:04 PM
1999EX's Avatar
Sorry...forgot to say it's got the 2.3 4 cylinder. I ran by Autozone and they hooked it up and it had no stored codes. I didn't think there would be as the light never came on. I put a set of plugs and wires on it just to say I did. Bought the car used so I don't know how long those plugs and wires were on there. Plugs that came out actually looked pretty good though, and were gapped right at 44. I guess I just have to wait till it does it again so I can check for spark or fuel issues.
Old Apr 21, 2012 | 10:35 AM
ghostpilot's Avatar
Mines is the VTEC 2.3 4 cylinder as well.
It was a good idea to replace the plugs and wires anyway since now you know when they were last replaced and is not that expensive to do.
If it happens again I would definitely look into the main relay.
Good luck.
Old Apr 25, 2012 | 09:35 PM
1999EX's Avatar
Smile
well...it broke for good today. wouldn't start cold. took dist. cap off and removed the coil and ign. module and took to autozone and had em tested. it was the module. $122 and 10 mins. later she starts right up
Old Apr 25, 2012 | 10:29 PM
crispin's Avatar
well that was great that you got it running but you sure paid a lot for it.
here is the same part for $48.00 Beck Arnley 180-0264 Electric Ignition Module | eBay
Old Apr 26, 2012 | 07:34 AM
1999EX's Avatar
yeah...I guess you pay for convienience. if I had ordered online I couldn't have fixed it the same day.
Old Apr 26, 2012 | 07:50 AM
crispin's Avatar
I know - I shop at Autozone myself their pricing is weird, some items are cheaper than I can find anywhere and some are 2x - 3x higher than anywhere else.
Just like you said you are running again so that was worth a little extra.
Good job fixing your problem.
