Wet at thermostat housing
Old Oct 5, 2015 | 09:09 PM
BlackLX4's Avatar
Default Wet at thermostat housing
I just replaced the thermostat. I made sure the thermostat and its seal were correctly positioned and properly seated before I installed the housing and tightened down the bolts. I drove it ten miles home and checked it, and it's wet on the bottom of the housing. The mating surfaces are flush and tight with no gap. Is it normal for it to get a little wet at first?
Old Oct 6, 2015 | 04:46 PM
BlackLX4's Avatar
Update: so it's actually not wet at the thermostat housing, but rather it seems to be coming from the lower hose where it joins the thermostat housing. Time for new hoses and clamps?
Old Oct 6, 2015 | 06:54 PM
The hose aluminum end fitting can be encrusted w/ a buildup of water minerals and interfere w/ reseating when hose is removed. You can use a small wire cable as a flexible file to remove the crusty buildup.
New hose may be indicated, depending on age/brand. OEM hoses are a cut above aftermarket hoses.
Old Oct 7, 2015 | 10:45 PM
BlackLX4's Avatar
By wire cable, do you mean like a cable tie or something like that?
Old Oct 8, 2015 | 08:59 AM
rockhoundrob's Avatar
I think he means wire brush...
Old Oct 8, 2015 | 09:09 AM
Foxi D'elegance's Avatar
Wire brush or sand paper works well for that. Very good advice that's something alot of us overlook is that crust on the inlets.
Old Oct 8, 2015 | 01:28 PM
I meant a small diameter twisted wire cable. It will remove the crusty deposits. A brush will bet some but access to all sides is usually impossible. The wire allows you to rotate the contact surface to access difficult position. However, a good brush may still be necessary.
nitwit
May 4, 2013 05:33 AM
pouncer11
Jun 9, 2012 04:06 PM
harris23
Jul 9, 2011 09:29 AM
eric123
Feb 10, 2008 08:49 PM
LaminatedKitten
Dec 21, 2005 11:23 PM
