What should I gap my spark plugs to?
Old Jun 15, 2012 | 05:55 PM
letsclique's Avatar
Default What should I gap my spark plugs to?
I noticed in my Haynes Repair Manual, in the tune-up section it says a spark plug gap between 0.039 to 0.043 inch. So does that mean anywhere between those two gap measurements is fine (Of course I would try to gap them all to the same gap)? Also, it shows in the book that the spark plugs should be torqued to 156 in-lbs. How much is that in foot-pounds?
I just used a free conversion website, and it shows that 156 in-lbs is 13 ft-lbs.
1990 Honda Accord DX, 2.2 L, Manual
Old Jun 15, 2012 | 06:36 PM
If you buy the NGK ZFR5F-11 plugs for your car they should be gapped properly out of the box. Most autoparts stores carry these. They are the copper V-power plugs.
Old Jun 15, 2012 | 11:47 PM
UhOh's Avatar
I don't worry about any of this gap stuff any more. I just ask the auto parts store for plugs to fit my car and
I install them w/o checking further. No problemos with this approach.
I use Iridium plugs since I want longest life/no maintenance, but that's not your question.
Old Jun 16, 2012 | 12:49 AM
To answer your question; yes, the gap measurement can be between 0.039 to 0.043 inches. Service manual specifications are 1.1mm (+0, -0.1) or 0.043 inches (+0, -0.004).
Torque would be 13 ft-lbs., the same as what the free conversion website stated. If you did not have a torque wrench, then you can finger tighten the plugs till they seat, then tighten 1/2 turn with a ratchet (see attached instructions from owner's manual excerpt on doing it without a torque wrench).
Attached Thumbnails What should I gap my spark plugs to?-spark-plug-gap-torque.jpg   What should I gap my spark plugs to?-1990-accord-spark-plugs.jpg
Old Jun 16, 2012 | 06:26 PM
letsclique's Avatar
Nice, those are the kind of plugs I bought yesterday. O'Reilly said the gap should be .044 for these plugs.
The man at O'Reilly who was helping me get some of the stuff I needed to do the spark plugs, etc., tried to sell me the round gapping tool. But I read in the Haynes manual to buy a gapping tool/that is the wire type. I regret that now, because the metal part that is used to bend the spark plug electrode to get the correct gap was starting to bend. Next time I will get the round gapping tool because its more durable than that flimsy metal.
Old Jun 16, 2012 | 06:38 PM
letsclique's Avatar
I bought an inch-pounds torque wrench yesterday so I could torque to 156 in-lbs, but I was wondering how to set it to 156 when It had marks for 120 in-labs and then I think 230 inch pounds. I was also trying to beat the sunset so I ended up using my Harbor Freight torque wrench, set to 13 ft-lbs. Good thing is now I have an inch-pounds torque wrench to add to my slowly growing arsenal of tools.
Zarcu
Mar 31, 2013 08:40 PM
black94EX
Feb 13, 2012 06:58 AM
gshock
Feb 23, 2009 12:24 AM
thunder_x
Sep 27, 2007 09:29 AM
trukid21
May 2, 2007 03:55 AM
