What should oil pressure gauge read?
Hey, don't flame on me cause I have searched for awhile!
Just installed mechanical oil pressure gauge in my 96 accord ex-r. F22b1. What should my pressure be at approximate across the board? When warm at idle I'm getting about 18-20 psi. By 3k the gauge reads 65-75. Sometimes climbing to 80psi. I'm just curious if that is what this engine runs for pressure or if my gauge is faulty. My shop is closed for the holidays but I want to know !! Any input is appreciated! Thanx!! |
The readings you're seeing look pretty normal to me.
Minimum oil pressure specs are 10 psi at idle, and 50 psi at 3K rpms.
good luck |
Ok cool.
Im guessing the higher pressure is for engaging vtec? The readings just seemed a little high. Cold start ran 80psi this morning. When my shop opens back up I'm going to hook my snap-on oil pressure tester gauge up to the block and get some true readings. Thanx for your time and input! |
