What should oil pressure gauge read?
Old Dec 23, 2013 | 10:18 PM
Phantum's Avatar
Default What should oil pressure gauge read?
Hey, don't flame on me cause I have searched for awhile!
Just installed mechanical oil pressure gauge in my 96 accord ex-r. F22b1. What should my pressure be at approximate across the board?
When warm at idle I'm getting about 18-20 psi. By 3k the gauge reads 65-75. Sometimes climbing to 80psi.
I'm just curious if that is what this engine runs for pressure or if my gauge is faulty.
My shop is closed for the holidays but I want to know !!
Any input is appreciated! Thanx!!
Old Dec 24, 2013 | 08:06 AM
shipo's Avatar
The readings you're seeing look pretty normal to me.
Old Dec 24, 2013 | 11:19 AM
Minimum oil pressure specs are 10 psi at idle, and 50 psi at 3K rpms.
Old Dec 24, 2013 | 11:54 AM
Phantum's Avatar
Ok cool.
Im guessing the higher pressure is for engaging vtec? The readings just seemed a little high.
Cold start ran 80psi this morning.
When my shop opens back up I'm going to hook my snap-on oil pressure tester gauge up to the block and get some true readings.
Thanx for your time and input!
jroxz44
Dec 2, 2012 02:52 PM
tattoodwaitress
Jun 23, 2012 10:53 PM
jroxz44
Apr 26, 2012 12:11 PM
mshook316
Feb 2, 2009 07:24 AM
tcodi
Nov 22, 2005 12:45 PM
