What's the easiest way to get to the IACV on a 5th gen?
So I wanted to tinker around, and clean up the IACV (idle problems). As we all know, there's barely enough space between the IACV and the firewall to fit anything in there.
After about 10 or 15 minutes, I was finally able to get the top bolt loose, but the bottom one is nigh impossible to get to, and the bolt is on way too tight. I did find the sticky thread in the DIY section, which is very helpful, but it's just the first hump I have to get over, haha.
What's the easiest work around this?
HondaAficionado
Jul 29, 2010 01:27 PM
Should I just remove the entire throttle body and give it a good cleaning?
