-   -   wheel bearing/hub?? (https://www.hondaaccordforum.com/forum/general-tech-help-7/wheel-bearing-hub-50907/)
honda girl Oct 18, 2012 04:29 PM
wheel bearing/hub??
I have a 92 honda accord EX. i took it to the mechanic today and he said my wheel bearing is shot and to replace it its gonna run me about 450.oo because there is a special way to change it that is specific to the 92 model and year!! my question is, is that true?? should i get a second opinion? any advice would be good. i know the wheel bearing is bad, but i wnat to know if theres a special way to do it thats specific to the 92 accord?
thanks!
JimBlake Oct 18, 2012 05:41 PM
Well, special to all the Accords up to 1997, and it's not the same as most other cars. But get a 2nd opinoin because to me that sounds kinda expensive. Where are you located? Labor prices vary A LOT from place to place.
AccorDats Oct 18, 2012 06:45 PM
Hello. I don't mean to hijack your thread honda girl.
To Jim blake, i would like to know what is so special/different about these wheel bearings? Thank you
Goodluck honda girl
JimBlake Oct 18, 2012 08:37 PM
Not all that "special" but the installation is a bit strange compared to most other car brands. It's the "hub-over-rotor" configuration of the brake rotors (search for that phrase). Like I said it sounds like a high price, but I don't really know that for sure.
honda girl Oct 22, 2012 06:57 PM
ok. ill check it out. thanks for the advice. :)
PAhonda Oct 22, 2012 07:39 PM
Was the quote to replace one wheel bearing or both?
How long do you plan on keeping the car? You might want to consider doing the rotor over the hub conversion.
honda girl Oct 24, 2012 07:29 PM
it was to replace the front right (passenger) bearing and hub assembly. he said something about it being a (two-piece) bearing?? i dont know. its a 92 with 158,000 miles on it, so i would like to keep it for a while longer, ive put ALOT of work/money in it! :confused:
redbull-1 Oct 24, 2012 07:31 PM
Call or visit some other independent shops for quotes on replacing the wheel bearing. The other mechanic's pricing is high.
JimBlake Oct 25, 2012 06:55 AM
2 Attachment(s)
OK, here's a couple pictures showing the difference.
First picture shows the 1992 setup. The wheel bearing is #1 and the hub is #2. The hub isn't normally replaced, so maybe there's something wrong with it? Notice the hub is outside of the brake rotor (#19) so the rotor can't be removed without first removing the bearing & hub. That's the unique part.
Second picture is the newer setup, 1998 in this picture. This is arranged the way most other car companies do it. The bearing is #2, the hub is #3, and the brake rotor (#17) fits over the hub. This way the rotor can be removed easily without disturbing the wheel bearing.
Some people have converted it over to the newer setup, by getting knuckles, bearing, brakes, etc from a different car. Not sure if 1998 Accord parts are the best choice, maybe some year of Prelude. Hope someone will chime in about that.
moey Oct 25, 2012 09:08 AM
If they want to replace the hub I would definitely question that. I dont think they could diagnose a bad hub short of cutting it up and doing a metallurgical analysis they are pretty solid parts. Maybe when they said hub they were actually referring to just the bearing assembly, they probably were as hubs are not that cheap to come by except a junk yard.
