Which wheels fit what years?
Did a search and found no exact answer.
I have a 2006 4 cylinder sedan EXL. Will any wheels from years 03-07 fit my car? The wheels on mine are a little rough and I am trying to figure out what will fit and what won't. Thanks. |
As I told you in my PM to you..your a 5x115mm by 55mm wheel...that's what you are needing and I don't have any at this time..What year do you have a preference for...
WheelBrokerAng .. :) |
I just want to know what wheels (if any) from 2003+ Accords will fit my car. I already knew the specs of the wheels I currently have, I just don't know the specs of the wheels from 2003 and on. They all seem the same, but I don't know for sure.
I'm looking for a 5 spoke type style. |
*Bump*
Are there other Accord OEM wheels from 2003-2007 that are 5x115mm by 55mm? Any easy way figuring out which ones? BTW....Is 5x114.3 and 5x115 the same? I thought the wheels on my car were 5x114.3. |
Just by looking up the hub, knuckle, and brake caliper assembly, all the 03-07 4-cylinder accords are the same.
The V6 uses the same knuckle, but the hub and brake calipers are different than your 06 4-cylinder EXL. I don't know what the difference is between them, so V6 rims may work. |
more info for you
Originally Posted by Yonomo
(Post 247859)
*Bump*
Are there other Accord OEM wheels from 2003-2007 that are 5x115mm by 55mm? Any easy way figuring out which ones? BTW....Is 5x114.3 and 5x115 the same? I thought the wheels on my car were 5x114.3. No-114.3mm converts to 5x4.5 inchs and 115mm converts to 5.42 inchs |
Sorry to sound stupid about this or whatever.
WheelBrokerAng says my wheels are 5x115, but I read somewhere else they are 5x114.3. Anyone have exacts on this? WheelBrokerAng, this seems like it would be your speciality. What can you tell me? Is 114.3 wrong? Will all wheels from 2003-2007 fit my car? Do you know an easy way to tracking which wheels will fit? |
