Which wheels fit what years?
Old Jul 13, 2011 | 11:00 PM
Yonomo's Avatar
Default Which wheels fit what years?
Did a search and found no exact answer.
I have a 2006 4 cylinder sedan EXL. Will any wheels from years 03-07 fit my car? The wheels on mine are a little rough and I am trying to figure out what will fit and what won't. Thanks.
Old Jul 13, 2011 | 11:16 PM
As I told you in my PM to you..your a 5x115mm by 55mm wheel...that's what you are needing and I don't have any at this time..What year do you have a preference for...
WheelBrokerAng ..
Old Jul 14, 2011 | 12:40 PM
Yonomo's Avatar
I just want to know what wheels (if any) from 2003+ Accords will fit my car. I already knew the specs of the wheels I currently have, I just don't know the specs of the wheels from 2003 and on. They all seem the same, but I don't know for sure.
I'm looking for a 5 spoke type style.
Old Jul 19, 2011 | 10:02 PM
Yonomo's Avatar
*Bump*
Are there other Accord OEM wheels from 2003-2007 that are 5x115mm by 55mm?
Any easy way figuring out which ones?
BTW....Is 5x114.3 and 5x115 the same? I thought the wheels on my car were 5x114.3.
Old Jul 19, 2011 | 11:49 PM
Just by looking up the hub, knuckle, and brake caliper assembly, all the 03-07 4-cylinder accords are the same.
The V6 uses the same knuckle, but the hub and brake calipers are different than your 06 4-cylinder EXL. I don't know what the difference is between them, so V6 rims may work.
Old Jul 20, 2011 | 01:53 AM
Lightbulb more info for you
Originally Posted by Yonomo
*Bump*
No-114.3mm converts to 5x4.5 inchs and 115mm converts to 5.42 inchs
Old Jul 20, 2011 | 08:37 AM
Yonomo's Avatar
Sorry to sound stupid about this or whatever.
WheelBrokerAng says my wheels are 5x115, but I read somewhere else they are 5x114.3. Anyone have exacts on this?
WheelBrokerAng, this seems like it would be your speciality. What can you tell me?
Is 114.3 wrong?
Will all wheels from 2003-2007 fit my car?
Do you know an easy way to tracking which wheels will fit?
fordmechanic
Feb 13, 2011 12:13 PM
Ryans71
Dec 4, 2009 06:48 AM
thunder_x
Jan 4, 2009 01:25 PM
Chaz57
Jun 19, 2007 06:48 PM
abelh7
May 1, 2006 02:28 AM
