Oil pan gasket changed
Old Jul 20, 2011 | 12:24 AM
sst's Avatar
sst
Default Oil pan gasket changed
Hi, I just changed my oil pan gasket and had trouble removing the transmission dust cover for 93 Honda Accord SE. Now I'm having alot of trouble reinstalling it. It uses 3 small bolts. Also I'm not sure if I overtightened the pan bolts. I didn't use a torque wrench. Minimun drops of oil drip out, I'm guessing It's pooled oil. Any suggestions thanks. Steve!
Old Jul 20, 2011 | 01:51 PM
Tek310's Avatar
well whatever is in the way, try removing it to reinstall dust cover.
and for the oil seepage. do you clean the gasket mating surfaces? wipe down both the pan and block before reinstallation?
the bolts dont need to be super tightened. its easy to over tighten and warp the pan or strip the threads.
if pan is warped, use a ball peen hammer to straighten it back out
ccookie66
Apr 12, 2019 04:43 PM
93Accord2.2
Nov 6, 2013 11:53 PM
frost506
Jan 16, 2012 07:21 PM
mcrisost1999
Jul 10, 2005 07:13 PM
Shocker
May 4, 2005 02:03 AM
