Oil leaks...oil pan gasket?
Old Mar 27, 2014 | 09:35 PM
ccookie66's Avatar
Default Oil leaks...oil pan gasket?
Hello! My Accord had a leaking valve cover, so I changed that. But now I am noticing oil spots wherever I park. I climbed under it and checked to see if I could find out where it is leaking, and I noticed there is a lot of oil around the oil pan. But I also noticed the entire engine under there was covered in oil. But then I was thinking maybe the oil is just from the oil pan gasket and blowing all over the bottom of the engine...it uses about a quart of oil in like 2 days, depending on how much I drive. And I am pretty sure it isn't burning oil, since I can't smell oil in the exhaust, and I can see it leaking onto the ground...so before I dish out money to fix the oil pan gasket, does that sound like that is what it is? Thanks!
Old Mar 28, 2014 | 06:24 PM
Sorry, just too many places it could be coming from.
Really need to clean up everything and then do some more looking. Could be the pan, the oil pressure switch, left over vc oil, seals from the timing belt area, ect.
Old Apr 1, 2014 | 03:19 AM
rhamza161's Avatar
take that thing to the car wash and use the engine cleaner on all the oil to remove it. spend a few long minutes cleaning it all up. wait a few days and check again, you'll find out where it is coming from easily then. That's the only way to truly know unless you start replacing everything...a lot of spots it could be coming from.
Old May 16, 2014 | 06:40 PM
patkelly1336's Avatar
Mine was leaking a few months ago, and I noticed smoke starting coming off the manifold and front pipe. Turned out the bottom of the oil pan rusted out (Live in Wisconsin, salt eats away at that stuff)
Old Apr 12, 2019 | 04:43 PM
Paul Chorniy's Avatar
Default check your blow by!
if its leaking from everywhere the engine might have a blowby. in such case the engine starts leaking frm main seal back seal valve cover basically everywhere it wants....
good luck.
frost506
Jan 16, 2012 07:21 PM
cooper4x4
Nov 29, 2006 07:19 PM
meazz1
Feb 21, 2006 09:25 PM
mcrisost1999
Jul 10, 2005 07:13 PM
Shocker
May 4, 2005 02:03 AM
