where is the blower motor resistor 2003
Old Mar 15, 2008 | 01:57 PM
bglovept's Avatar
Default where is the blower motor resistor 2003
Ok, the blower motor quit working. It works when plugged directly to a 12 volt battery. I took it to the dealership and the service writing underhandedly told me it was the resistor. He would not give me any more information. I have the blower motor out. Where is the resistor? Thanks.
Old Mar 15, 2008 | 02:47 PM
Default RE: where is the blower motor resistor 2003
I don't know specifically on that model, but resistor is usually on the blower or evaporator housing nearby. Relatively large and hard to miss. Follow connector from blower backwards.
Old Mar 15, 2008 | 05:23 PM
hondadude's Avatar
In this pic it is number 11 I'm fairly certain it is in the top of the ducting to the drivers side of the blower unit.
Old Mar 15, 2008 | 06:16 PM
bglovept's Avatar
Thanks, I found it to the back left of the blower attached with 2 screws to the firewall on the inside. Changed the resistor and now I have AC again.
Old Sep 23, 2008 | 04:11 PM
BU50's Avatar
Sorry to pull up such an old thread...
but may ask about the problem that you had... cuz my AC is not working and i wonder if that is the same case as yours was...
in addition, someone told me it could be the Blower Motor Resistor that is causing my problem??
Old Sep 23, 2008 | 08:38 PM
Does the blower work at any speed or not at all? Did the blower quit working suddenly or did you gradually lose 1 fan speed after another?
Try thumping the blower module w/ your hand. If the blower starts and runs, the blower brushes are worn out. They are not replaceable and a new blower motor is necessary.
Old Sep 24, 2008 | 03:11 AM
BU50's Avatar
i have suddenly lost the blower... it stopped working completely...
well, the thing is i dont know where is the blower??? someone told me its under the dashboard beside the glove box!!!
is there any guide of how to reach there??? i have never unscrew any screw in the car... i want to do so but in the right way...
so can anyone help a little bit more?
Old Sep 24, 2008 | 07:29 AM
Honda Dude gets the #1 star with his always great pictures of " Where Its At "
Thanks HondaDude ....
Old Sep 24, 2008 | 07:33 AM
ORIGINAL: BU50
COMON Now Member..Read about this post
And look at the pictures before you posted..
Old Sep 24, 2008 | 11:57 AM
BU50's Avatar
I will try my best with the blower n with keeping you guys updated
