Where is the Cruise Control actuator?
Old Jan 17, 2008 | 06:37 PM
asc5
Default Where is the Cruise Control actuator?
I got my car back from the mechanic with timing belt, throttle body, etc done to it. I believe he forgot to hook the cruise control vacuum lines back up. I would like to know where the cruise control actuator/vacuum lines are under the hood so I can inspect to see if I am right and reconnect them.
It is a 1992 Honda accordex
2.2 liter
Thanks for your help...
Old Jan 17, 2008 | 07:25 PM
hondadude's Avatar
Default RE: Where is the Cruise Control actuator?
underhood, just behind drivers headlight, Big round black cylinder looking affair.
There is a vacum line that runs toward the drivers side fire wall that hooks up to an orange/white check valve.
Old Dec 3, 2012 | 02:13 PM
Mick N's Avatar
Default Cruise Control
Hi hondadude, I have a question for you concerning the cruise control on a 94 Accord. It seems like it has a mind of it's own. Sometimes it works and sometimes it doesn't. If it continuely didn't work, I'd say check the fuses, but this thing works sometimes and sometimes not. There are times when it is working, like driving for an extended period of time, and then all of a sudden it shuts itself off, then it usually won't work again for an extended period of time. Any suggestions? Thanks, Mick N
Old Dec 3, 2012 | 09:05 PM
Hondadude might chime in...or others.
When the cruise stops working.....try honking the horn while setting the cruise, yes sounds stange but so am I.
Is this an auto or manual trans car, as that is another "tree" to go down.
Old Dec 5, 2012 | 08:32 AM
Mick N's Avatar
It's an automatic transmission. Thanks for the advice, I'll try honking the horn and setting the cruise today.
deckerhonda
Jan 24, 2006 09:12 PM
wskipper
Nov 19, 2005 03:49 PM
SeminoleB
Nov 9, 2005 01:52 AM
rabbit
May 3, 2005 01:28 AM
austinbc1
May 2, 2005 08:16 PM
