Whining noise!
I hear a whining noise every time I turn the steering wheel on my 2008 Accord. What could it be?
4-cyl? V-6?
Check the belt tensioner. There's some markings on the tensioner to indicate the belt stretched to its limit where you need a new belt. Another way is carefully spray some water on the belt & try the steering. If that makes it quiet, you know it's the belt rather than something more complicated. Sometimes old belts get hard & slippery even if they aren't stretched too far. One possibility is leaking O-rings at the hose connections at the pump. They let a bit of air into the pump. Search around the General Tech. forum because someone has posted a tech. bulletin (maybe PAHonda?) |
Hello New Member and Thank You for joining the HAf..
WheelBrokerAng :) |
| All times are GMT -5. The time now is 02:33 AM. |
