Why doesn't the USB port work on 2019 Accord?
Hi, I just bought a used 2019 Accord EX-L but the front USB port and Cig Lighter do not work at all. However, the center counsel USB and Cig Lighter work fine.
My idea was to swap the fuses #16 (back) and #50 (front) between the two, but the center counsel has no fuse in the #16 slot! How is it working then? The Front Fuse ( #50) looks good anyways, so I think I'm in over my head. Any help? |
I don't have a wiring diagram for your 2019 accord, so I'm not sure what fuse is powering the power/usb.
If you have an adapter that can plug into the cigarette lighter, try it on both front and center console to see if that is working? If you have a test light, you can quickly run through the fuses to find any fuses that are blown. There are some good youtube videos on how to quickly test car fuses that will help. |
I have the same problem as DBC 20 in this thread except that I have a 2013 Accord EXL. No power at all to the USB port and the cig lighter port at the dash but I do have power to the cigarette lighter port at the center console. Fuse for cig lighters is fine and it looks like there is no fuse for the USB port as it is connected to the radio which works fine. Appreciate any help.
