Why doesn't the USB port work on 2019 Accord?
Old Apr 17, 2022 | 07:35 PM
DBC20's Avatar
Default Why doesn't the USB port work on 2019 Accord?
Hi, I just bought a used 2019 Accord EX-L but the front USB port and Cig Lighter do not work at all. However, the center counsel USB and Cig Lighter work fine.
My idea was to swap the fuses #16 (back) and #50 (front) between the two, but the center counsel has no fuse in the #16 slot! How is it working then? The Front Fuse ( #50) looks good anyways, so I think I'm in over my head.
Any help?
Old Apr 18, 2022 | 12:13 PM
I don't have a wiring diagram for your 2019 accord, so I'm not sure what fuse is powering the power/usb.
If you have an adapter that can plug into the cigarette lighter, try it on both front and center console to see if that is working? If you have a test light, you can quickly run through the fuses to find any fuses that are blown. There are some good youtube videos on how to quickly test car fuses that will help.
Old Dec 29, 2023 | 04:28 PM
bdw101's Avatar
I have the same problem as DBC 20 in this thread except that I have a 2013 Accord EXL. No power at all to the USB port and the cig lighter port at the dash but I do have power to the cigarette lighter port at the center console. Fuse for cig lighters is fine and it looks like there is no fuse for the USB port as it is connected to the radio which works fine. Appreciate any help.
Schleprock
Dec 9, 2017 06:24 PM
Preston Niemeyer
Dec 19, 2016 10:09 PM
dgp1961
Aug 25, 2016 05:49 AM
smokinleroy
Dec 11, 2014 06:52 PM
coolgmslife
Jul 5, 2007 10:36 PM
