wierd noise
Old Jan 2, 2008 | 08:11 AM
wetwilly2256's Avatar
Default RE: wierd noise
the most i can tell u is somewhere in the engine (not trying to be an smarta**) but i can feel the gas peddal vibrating, to me it sounds like the sound that gears rubbing against each other make.
Old Jan 2, 2008 | 09:25 AM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: wetwilly2256
somebody told me the it my be the v-tech turning on
Not a chance.
Does it always happen when you are rolling? Or can it happen when you are at a complete stop?
Wheel bearing maybe?
Possibly the brake caliper is not fully releasing from the rotor?
Old Jan 2, 2008 | 09:40 AM
falkore24's Avatar
If it is only when you start to take off and at gear changes when the gas is floored, it might be engine mounts. The symptom of this is wheel bounce when I'm not pushing it hard enough to smoke the tires.
Old Jan 2, 2008 | 11:33 AM
it when i actually push the gas, it doesnt matter if i step on it or if i start off slow it does the noise, and if it is the engine gaskets, what would it take to fix it
Old Jan 2, 2008 | 11:39 AM
falkore24's Avatar
not gaskets .... mounts. To replace them, you have to unbolt them and the bracket that is bolted to the engine while supporting the engine (I used a floor jack and a 2x4). Be carefull to not break the plastic vacuum tubes ..... connect them to the new mounts and rebolt everything together. The top passanger side didn't require support and was changed in about 20 minutes. I'd recommend having a mechanic do it if you are not confident to do the work.
Old Jan 2, 2008 | 12:44 PM
i am definatly going to let a mechanic work on it, ill go back to the dealer and ask him cause i have a warranty and i just got it, im not touching anything under that hood that i dont know about, not with my luck anyway. thanks for all your help I really appreciate it.
Old Jan 2, 2008 | 07:00 PM
  #17
HondatechAV6's Avatar
i stand by my first assumption...probably a cat heat shield. [sm=shades.gif]
Old Jan 3, 2008 | 07:53 AM
  #18
So if it is a cat heat shield than what do i do to fix it? is it a simple fix or does a mechanic have to do it
Old Jan 3, 2008 | 08:16 AM
  #19
falkore24's Avatar
Get under the car when it's cooled off. Hit the bottom of the cat with the pinky side of your fist and see what kind of sound it makes ..... if you hear metal to metal contact, cut the shield off of the cat and don't park on top of dried leaves.
ALL HAIL "FIERO" THE FIRESTARTER!!!!!
Old Jan 3, 2008 | 05:47 PM
  #20
hahah, awesome pic, hehe!
yeah, you can unbolt it(using a 10mm socket & ratchet) and a 12mm wrench. it may be rusted to badly. that means you have to cut it off or be creative in getting it off. some people just buy a few hose clamps and clamp it down around the cat tightly. check it out first.
