wierd noise from the brakes
Old Sep 24, 2008 | 05:25 PM
jamdown2626
Default wierd noise from the brakes
i have an 03 EX 4cyl and ive noticed some wierd noise coming from the brakes. i almost sounds like something is scrapping against the rotors, and idk if i just need new brake pads or if something bigger is wrong. i kno this sounds stupid but it doesnt really sound like just worn brakes pads bcuz i kno that sound! lol
Old Sep 24, 2008 | 05:33 PM
falkore24's Avatar
Default RE: wierd noise from the brakes
Could be the squealer telling you "I need new pads!!!!"
Old Sep 24, 2008 | 05:34 PM
hondadude's Avatar
There is a "squealer" tab on the inside pad that rubs against the rotor when the pads wear down to min spec.
Old Sep 25, 2008 | 04:38 PM
brayner's Avatar
jamdude, get the wheel off and have a look!!
Old Sep 26, 2008 | 07:38 PM
HondatechAV6's Avatar
lol, most the time it's your rear pads. i see these things worn metal to metal every 20k from normal use
Old Sep 30, 2008 | 08:21 AM
Gary L's Avatar
I just had this problem with the fronts and found a shim that is glued on the caliper side of the outter pads had dislodged and was rubbing on the rotors of both sides.
I reglued it and hope the problem is solved but I can't figure out why it even happened unless the installer failed to relieve the piston and did it while sliding the caliper back on.
Remove the wheel and you should be able to see it if this is the culprit.
Gary L
stevepasq
Sep 12, 2010 01:12 PM
jamdown2626
Sep 24, 2008 05:35 PM
wetwilly2256
Jan 9, 2008 03:51 PM
Slowaccord
Aug 22, 2007 06:37 PM
nixalot
Aug 10, 2006 04:54 AM
