Will not start!!!!!
Old Jul 30, 2009 | 06:19 PM
cmpf1975
Default Will not start!!!!!
I have a 90 accord ex with a 2.2. It will not start and I have done the following to it, change dist. cap, new plugs, checked timing belt and made sure it was in time, charged up battery, checked fuses and still nothing. I am getting fuel and spark.I even tried spraying a little bot of starter fluid in the throttle body and still notthing. It turns over great. I am lost can anyone point me in the right direction you help would be great. Thanks
Old Jul 30, 2009 | 08:11 PM
How did you verify the no spark? Grounding a plug may produce a weak spark, fooling you into thinking the spark is ok. Hookup a timing light on the wires, and see if enough spark is generated to flash the timing light.
Also, make sure that you have the spark plug wires installed in the right order on the distributor cap.
Old Jul 30, 2009 | 08:41 PM
oneroom42's Avatar
any issues with the check engine light coming on before it wouldnt start? i am fighting a battle myself with my 91 accord ex. keep us informed!!
Old Jul 31, 2009 | 01:16 PM
deserthonda's Avatar
if you sprayed fluid in the throttle body and still no start,, it is a spark issue chk the coil and ignitor , also the rotor, there is a write up on the DIY section ,,
Old Jul 31, 2009 | 04:14 PM
cmpf1975
No problems with check engine light but I hooked up the timing light and got nothing!!!
Old Jul 31, 2009 | 06:53 PM
Now you verified a spark problem.
Turn key to II position and see if you have 12V on the blk/yel wire that leads to the coil. If no voltage, then suspect ignition switch or wiring.
If you have 12V, then either the coil or ignitor should be tested.
Old Aug 8, 2009 | 06:31 AM
cmpf1975
I replaced the coil and the ICM still nothing. I am not sure but I think the wires on the cap are right.
Old Aug 8, 2009 | 06:03 PM
mryome1999
I had a similar problem also. My distrubutor was leaking oil into the body.(bad bearing) The oil built up and it cooked the wires to the ignitor and the magnetic pickup. The insulation on the wires were falling apart. I tried to fix. Ended up replacing the distrubutor. Took off the valve cover and redid the gasket for the spark plug holes. Holes were full of oil. When all was done, started car, now runs perfect.
Old Aug 8, 2009 | 06:16 PM
let me get this right.......
you are getting fuel, you are getting spark, timing belt is ok..cam timing is ok,no chk engine lite on,,, still car does not start,,
plug wires installed in proper order?? try something for me ,, i am wondering if by now you got a cylinder wash...any fuel in the oil ?? compression ok ? remove the plugs, put a bit of tranny fluid in each cylinder, crank engine,after cranking put a bit more oil again, install plugs , try starting it that way
Old Aug 8, 2009 | 07:05 PM
91accorddxbuds
yes the same is for me i have the same problem im not getting a spark and my car wont start!
