Wired remote start.. how to... ?
I want to make a switch(es) to start my car from inside when it's cold outside.. So here I am thinking, what do I need, I never have put one on a 5spd before- not to mention that the state has a breathalyzer thing on my car for chrissakes
So what do I need, I remember a 5spd needs some extra relay, right?
So I would like to end up with this:
1. Toggle switch for ignition on (where everything lights up on the dash)
2. Momentary switch for clutch safety switch thing
3. Momentary switch for the starter
Anyone know where I can get the color codes for everything? I'm going to put it all in a quick connect harness
Thanks
Thanks
I don't need some big air tube, I need a cat5 extension cable
Any other way may be circumventing the breath-a-lyzer lockout.
I also thought about just letting some woman stay here for awhile and do all of that stuff for me, too... hahaha!!
Does a block heater keep the oil warm, too? I have heard that it is a bad idea to keep the oil warm when it's cold outside due to condensation- is that stupid or true?
I've seen dipstick heaters and freezeplug heaters and radiator hose heaters
I think the synthetic oil flows fine on cold starts so I'm more concerned with not freezing to death that anything at this point but I don't want to hurt the car, either, you know?
A block heater will keep the coolant warm (frost plug or hose type)......and to be clear, there isn't the usual frost plug on this car but there is a block drain that a threaded heater can screw into.
I've seen advertized magnetic 120v heaters that stick to the oil pans from the outside.
Seemed to me the easiest to mount, and since warm air rises, should keep block warmish ... just no experience here.
tell us what you do and how it works ...
Maybe I could use that when I change the water
Do you know if this car has a collant air bleeder anywhere?
If oil is warmer than the surrounding air there will be no moisture condensation into the oil.
Well hell that's good to know
I always thought any time you had a temperature difference there was a potential for condensation. I don't really understand how condensation works. Anyway, if that is the case- that sounds like a good option to warm up the whole engine
