wont stay running got fuel got spark
Old May 20, 2011 | 11:05 AM
mixedboydriver's Avatar
Exclamation wont stay running got fuel got spark
Have a 92 accord recently ran out of gas and a week later bogged out while driving and no more driving . It would still start but as soon as I put it in drive or reverse and hit the gas it would cut off . So I had the fuel filter changed the tps changed and then another throttle body complete cleaned the fuel injectors and the egr valve . It will start and is a lot better than before sound wise but just won't stay on now . Please help I checked the codes with the 2 wire connector near ecu(ecm) and got a 0 which says ecu . From there I looked at a site and it fits into a possibility of a bad ground for the ecu besides that I think its possible its the iacv or the fitv . What's your take on this please help I need to get it running and staying running and driving
Old May 20, 2011 | 12:40 PM
From your description, I would suspect a failed ignition keyswitch assy. When engine cuts off, does the Alt and Check Engine Light come on or stay Off? If it stays off, the keyswitch assy is highly likely.
Old May 20, 2011 | 12:58 PM
Exclamation gonna check
What if it stays on . Any ideas to that . I'm going to check when I get off of work I'm gonna check . Thanks though hope u have a response to that
Old May 20, 2011 | 04:18 PM
its an automatic can i still do that and what will that hopefully do
Old May 20, 2011 | 04:41 PM
You said that you got a code 0 on the ECU. What happened when you shorted that connector and turned the key to the II position?
Can you get the car to stall out by shaking the key while the engine is running?
Old May 20, 2011 | 04:43 PM
Exclamation update !!!!!
ok so i went and started it .. i have a better description now . for one when started it surges to about 2500 rpms and then down to around 500 or 600 and bogs out . but when it cut out the check engine light is not on . please any ideas and do you think its the ignition keyswitch assy (texas) ? help
Old May 20, 2011 | 05:10 PM
Exclamation another update
i did not try to shake the key when i did that but it did not stay on very long either.
Old May 20, 2011 | 05:14 PM
when i shorted the connector nothing happens besides the check engine light stays on no blinking at all
88hondaaccord
Oct 8, 2012 06:37 PM
wjtkb
Oct 7, 2012 07:17 AM
wrlips
Jun 22, 2009 08:59 PM
thedaveman89
Nov 26, 2008 03:37 PM
kangas
Mar 17, 2008 10:04 AM
