worry about changing out this O-ring?
Old Jul 21, 2013 | 05:40 PM
sgull's Avatar
Default worry about changing out this O-ring?
I have the engine in still in some state of disassembly after replacing the head gasket, and am putting things back together. In re-fitting the thermostat case (part 9) back onto the connecting pipe (part 12) in the following diagram, should I necessarily need to replace this o-ring (part 19)? It looks okay and hasn't been a problem before the disconnection of the case and the pipe, and would be at least a week of waiting to obtain a new one. I suppose perhaps ideally it would be best to go ahead and replace it but what I'm wondering is whether chances are still good it will seal just fine again without replacement, or should this o-ring definitely be replaced after this disconnection because if re-used will almost certainly not seal anymore? Any comments appreciated.
Attached Thumbnails worry about changing out this O-ring?-img_2362_zpsf661d2d3.jpg
Old Jul 21, 2013 | 05:48 PM
Personally I would reuse it. As long as its not hard and brittle it should be fine. And no sense waiting all that time for that part. Put it back together and if it leaks then order a new one.
Old Jul 21, 2013 | 06:22 PM
sgull's Avatar
Great. Just what I was hoping to hear. Re-use it I will. Thanks for the input.
Old Jul 21, 2013 | 08:05 PM
5.56mm_hickey's Avatar
agree with live2, throw some grease on it and use it
Old Jul 21, 2013 | 08:22 PM
sgull's Avatar
Aww. Already put the parts together and got it bolted in and everything now. Gotta put grease on it?
Old Jul 21, 2013 | 09:36 PM
EXV6NIGHTHAWK's Avatar
No. If it leaks, get a new o-ring.
Old Jul 21, 2013 | 10:05 PM
sgull's Avatar
Okay. Thanks for the replies. I won't worry about it. IF it leaks, I'll get a new one then. Probably generally a good idea to put a little grease or maybe vaseline or something on a new o-ring?
Old Jul 23, 2013 | 12:36 PM
A little grease or something would be good. I'd use something heavier than vaseline, but that's just because I've got several kinds of grease around the garage.
Not worth it to remove that just for grease. If it leaks, get a new O-ring and use a bit of grease this time.
Old Jul 23, 2013 | 01:39 PM
sgull's Avatar
Got it. Thanks Jim.
Donpop
Mar 3, 2013 03:49 PM
Shag Wagon
Oct 23, 2010 10:12 PM
1slowaccord
Feb 4, 2008 08:14 PM
thunder_x
Apr 21, 2007 05:28 PM
HondaRacer4Vtec
Dec 6, 2006 03:11 AM
