HAF Help & Suggestion Center Need help with HAF? Ask. Have a suggestion to better HAF? Tell us here.
Can I put a set of DSM 450cc injectors on a stock F22A1?
Old Nov 1, 2007 | 01:34 AM
freemind
Default Can I put a set of DSM 450cc injectors on a stock F22A1?
I have went with an MSD SS external coil,cap, 9mm wires and NGK platinum plugs and it still missing a little a little. I actually can feel it more now. The engine bogs down alittle when give it throttle at first. I had a newer JDM F22A1 put in about 9 months ago. The guy that did the swap put my old intake, injectors and distributor on the newer engine. It had the slight miss before and still does. I do not want to continue to buy parts without knowing what is really wrong.
I'd really appreciate any good advice.
-freemind
Old Nov 1, 2007 | 07:22 AM
BlkCurrantKord's Avatar
Default RE: Can I put a set of DSM 450cc injectors on a stock F22A1?
Injectors are way too big for a stock motor.
Old Nov 1, 2007 | 11:01 AM
falkore24's Avatar
What is your A/F ratio with the stock injectors ...... sounds like you're rich causing a choke condition ...... bigger injectors will make this worse and to go that big, you need E-manage to change the duration of the injector pulse.
Also, I think platinums are ok with the MSD, but I know that capacitive discharge systems burn the sharpened tips off of iridium plugs. Might be something to check.
matt073192
Mar 31, 2010 05:55 AM
22psi
Feb 16, 2008 01:38 PM
jaeal
Mar 24, 2007 10:58 AM
mbo1985
14
Apr 24, 2006 09:31 PM
